C2 rear wheel studs - NCRS Discussion Boards
C2 rear wheel studs
  • david maxwell
    C2 rear wheel studs
    I need to replace my rear wheel studs. Can this be done without taking apart the bearings and other parts?
  • Ed Jennings
    Re: C2 rear wheel studs
    It would be tough. However, if you can R&I your park brake shoes with the spindle in place, I think you can replace the studs. Some of the catalog vendors sell some sort of special tool that is supposed to allow you to R&I the shoes with the spindles in place. I've never tried this, and frankly don't see how to do it. If you can overcome this hurdle, I think you probably could replace the studs so long as they are not too long to go between the spindle and brake backing plate.
    • Ed Jennings
      • Dale S.
        • November 12, 2007
        • 1224
        I don't know how bad you wheel studs are, and this may not be pertaint to your problem, but we used to sell a wheel stud threader, It had like a threaded die that was cut in half. You put the halves on the thread that was bad up against the axel flange and it was sized so that a deep socket fit tight over it. You then backed the die off the stud with you deep socket. It worked real well, as usually the threads are bad towards the end. I have not seen a set of these in years. Dale
        • Dale S.
          • November 12, 2007
          • 1224
          • Ed Jennings
            I have used a regular hex 7/16" die and a deep well socket to repair the threads on wheel studs. You have to get it started straight, but after that it's duck soup. Now, if you have broken studs, that is a different story, obviously.
            • Ed Jennings
              • Mike Cobine
                It depends on the length of your stud. It seems like I tried to put in a replacement once and had to grind an 1/8th inch off of it, but it was an aftermarket stud from a regular auto parts place.
                • Mike Cobine
