1968 Heater/AC Wiring - NCRS Discussion Boards
  • Jay L. Flinders
    I purchased a 1968 327/350 with AC, power windows, tilt steerting. It has electrical wiring problems. One of which is the AC. I have purchased from electric limited the dash, AC, and power window harness. In puting them all in I find in the 1968 build book page H322 a note as follows: Remove 14 Ga Brown lead from prodution control switch connector & insert into ... Cut remaining (3) wires of production connector to within .25 of harness breakour & discard. One problem is where I show ... above is because the sheed of paper when photo copied was folded so I don/t know exactley what it says. The second problem is that in the picture on the same page it shows the instrument panel harness running left with what I presume is a brown wire coming out of it and being inserted in a connector going to the Production switch Heater control. This all seems simple and probably would be if I new what the complete note said. Also what color the wire is in the instrument panel harness that goes into the connector.
    Any help would be appreciated.
    Thanks Jay
  • Donald O.
    • May 31, 1990
    • 1580
    Re: 1968 Heater/AC Wiring
    Jay:
    At the bottom of UPC 60, Sheet E2, it should read:
    1. NOTE: Remove the 14 Ga Brown lead from production control swtich connector & insert into [8]. Cut remaining (3) wires of production connector to within .25" of harness breakpout and discard.
    2. Brown
    Don
