Currently detailing out the engine on my 66 with base engine. Couple questions I need help on. The lower alternator bracket was black when I took it off. The TIM&JG lists that being engine color...seems kind of logical to have it black since the upper arm is! Wondering the logic for it being engine color. My engine has been worked on so this is not a "original" finished part.
What is the finish of the bolt that attached the upper and lower alternator brackets to the waterpump? Engine color, cad/zinc? Also what is the finish on the bolts that attach the ignition wire support brackets to the intake manifold? I currently have those engine color.
Thanks!! Tim
Thanks!! Tim
