I assume that if I find any original 15x6 DC code rally wheel from any Chevy vehicle of the time, that it is the same as the ones used on Vettes?
Are all 15x6 DC code rally wheels the same?
Tags: None
- Top
Re: Are all 15x6 DC code rally wheels the same?
Tim,
You will want to search for DC wheels that do not have a date outside at the valve stem hole and the size of the DC characters should 1/4" in height. Sometime in late 67 or early 1968 the dating of DC wheels was stamped on the outside along with DC at valve stem hole and the DC character size was reduced to 3/16". I believe these were used for over the counter replacement wheels. Also in the lug nut area you will find GM KH only stamped on the LARGE DC, small dc (replacement)you will find stamped GM and K-1-8 or similar. Large DC are hard to find that are not rusted or bent. I am not saying this is gospel but what I remember from searching for wheels for my 67 roadsters.
H P Shuttleworth- Top
