1967 Fan Clutch - NCRS Discussion Boards
1967 Fan Clutch
  • Rick S.
    • January 1, 2003
    • 1203
    1967 Fan Clutch
    Can anyone tell if the 1967 Fan Clutch on Ebay is for a big block or small block. Item # 4524535020.
    Thanks in advance,
    Rick
  • Craig S.
    • June 30, 1997
    • 2471
    Re: 1967 Fan Clutch
    Rick - this is completely wrong for a midyear. The Schweitzer bar type clutch has a stamped front face with a radial starburst type look (not the style with the cast in starburst either. I have one, but can't post the picture.....Craig
    • Craig S.
      • June 30, 1997
      • 2471
      Fred Olivias Site
      Rick - the front face of the Schweitzer clutch should look like the upper left picture on Fred Oliva's website......see link below.......Craig
      Fred Olivia's website
      • Craig S.
        • June 30, 1997
        • 2471
        Re: Fred Olivias Home Page
        Here is the home page link for Fred's site....Craig
        Vintage Automotive Research - Fred Olivia
        • Rick S.
          • January 1, 2003
          • 1203
          Thanks Craig *NM*
          • David K.
            • January 1, 1999
            • 59
            Re: 1967 Fan Clutch
            Since I was taking pictures of my fan, I thought I might as well photograph the clutch.
            This came off my '67 big block.
            The engine is original, but I'm not sure about the fan/clutch (thus my post).
            I think I fixed the problem with the yahoo photo album.
            Several fan pictures here:
            fan clutch here
            • Craig S.
              • June 30, 1997
              • 2471
              Re: Thanks Craig
              Rick - by the way, the Eaton clutch that is period correct is the center clutch in Fred's picture. The currently available Eaton is the same EXCEPT the stamping on the front area is a different shape, unlike this original.... good luck finding a correct BB clutch, expect to pay $300 and up......Craig
              • Rick S.
                • January 1, 2003
                • 1203
                Re: Thanks Craig
                Craig,
                I'm looking for a small block clutch.
                Rick
                • Craig S.
                  • June 30, 1997
                  • 2471
                  Re: 1967 Fan Clutch
                  David - this clutch is an aftermarket replacement. The unit may be built by Eaton though, the front face is similar to the current GM available version, but GM never uses slots on the mounting flange to accomodate multiple bolt patterns.....Craig
                  • Mike M.
                    Director Region V
                    • August 31, 1994
                    • 1463
                    You can toss the fan clutch also *NM*
                    • Peter L.
                      • May 31, 1983
                      • 1930
                      TOUGH CROWD-You can toss the fan clutch also
                      Boy, this is a tough crowd!!!!!!!!!!!!!!!!!!!!!!!!!!!! Remember this set up has been said to be working fine. Perhaps the "original" GM set up didn't cut it and it was FoMoCo to the rescue????
