66 427/425 throttle return spring bracket paint - NCRS Discussion Boards
  • Peter M.
    • February 1, 1984
    • 361
    Re 66 427/425 throttle return spring bracket (the return spring bracket which is mounted off the intake manifold bolt) painted orange and if so - only on the outboard side because it was shot as a result of the overspray from the block painting process ?
  • Everett Ogilvie
    Re: 66 427/425 throttle return spring bracket pain
    I just dug up an old pic of a Bowtie car I used to own and the outside of the bracket is painted, and the inside is not.
    • Mike M.
      • May 31, 1974
      • 8365
      pete: if the bracket is a repo, put it to the magnet test as originals will grab the magnet, unlike some of the repos done in stainless. judges look for it. good luck, mike
      • Michael H.
        • January 29, 2008
        • 7477
        I agree with Everett. The bracket on my 66 still has about 50% of it's original paint. Probably completely covered on the outer side when new.
