Need new C2 Headlight Pivot Shafts - NCRS Discussion Boards
  • Scott Marzahl
    Can anyone comment on the quality of the Paragon "improved" pivot shafts. I need all four pivot shafts, any recommendations.
    Scott
  • Gerard F.
    • June 30, 2004
    • 3803
    Re: Need new C2 Headlight Pivot Shafts
    Scott,
    The one I replaced (left inner) was better and stronger then the original. Mine had cracked at the base connection to the pod. Also, their steel wye bracket is better then the original cast aluminum one which will crack if you tighten the shaft bolt too much. (Did that too).
    Get all new mounting bolts with the pivot shafts.
    Do you really need all four--lots of dollars.
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
    • Scott Marzahl
      Yep, too much money for sure. All four are corroded at the base where the shaft meets the flat part and in some spots all the way through.
