Message Deleted by Poster
(Message Deleted by Poster)
Tags: None
- Top
Re: instrument cluster& clock removal -1964
Take a peek at:
Harry
38513- Top
thanks harry , now I know what i'm getting into !!- Top
When you remove the front cluster screws one at a time, insert in their place 6" sections of all thread, that will screw back into the u-nut. It makes removing the bulbs, etc. a lot easier. PT
Attached Files- Top
- Top
Do you really have to remove the steering
column? I've removed the cluster from my 67 twice without removing the steering column, once with the steering wheel removed, and and the second time with the steering wheel in place. I'll admit it was easier with the steering wheel removed.
To remove it with the column in place, I just loosened the bolts on the brace holding the column in position, and the column dropped down far enough, so that the pin on the column collar cleared the hole in the bottom of the cluster. The collar could then be slipped to you, and the cluster can be tipped forward and pulled.
Or is a 67 cluster different from the one in the article?
Jerry Fuccillo
#42179Jerry Fuccillo
1967 327/300 Convertible since 1968- Top
