Need to change the plug wires on my '65 L76 driver and would appreciate your recommendation on a 7mm set that delivers good performance and routes nicely in the ignition shielding.
C2 Plug Wire Preferences?
Re: C2 Plug Wire Preferences?
If still available the original type Delco RFI suppression wires are a good bet. Resist the urge to buy metal core wires or some other wire that does not suppress RFI/EMI. Solid core wires will cause continuous radio static and won't improve performance over a properly functioning ignition system with proper RFI suppression wires.
Duke- Top
Although not NCRS correct, the performance is great, the fit is great, not cutting, and the cost reasonable. I have Moroso Blue Max Spiral Core wires installed on my daily driver 68, 70, and 85 Corvettes. Installed them on the 68 first about 18 years ago.- Top
