cam change 1962 C-1 - NCRS Discussion Boards
cam change 1962 C-1
  • Chuck S.
    • April 1, 1992
    • 4668
    I Would Like To Hear...
    What that sounds like, myself...Reggae band in an anvil factory? Now, if we can just find a volunteer.
    • Clem Z.
      • January 1, 2006
      • 9427
      Re: I Would Like To Hear...
      when i used to set hyd lifter cams at zero lash,no preload,to get more RPM,no lifter pump up and it was quiet so i am guessing that a couple of thousands may sound just like solids.
      • Chuck S.
        • April 1, 1992
        • 4668
        #18
        Clem, I have no idea how much "lash" was in one of my 66's hydraulic lifters (normal wear, about a year old), but it sounded for all the world like a knocking rod. I figure if you had too much lash in all sixteen, you would have yourself a nice little rythm orchestra...and a car you couldn't give away.
        I adjusted the valves as per the service manual with the engine running...to my great relief, that knock went smooth away as I cranked in the prescribed pre-load.
