bolt size and thread ? - NCRS Discussion Boards
  • Kent S.
    • July 31, 2004
    • 5
    About to remove engine to detail and repair oil leak (327). What size and thread bolt is needed to mount to engine stand? ( have not been able to remove existing bolts while under car ). Thanks for your help. Kent
    Re: bolt size and thread ?
    3/8"-16, Grade 8; length depends on the length of the tubes on your engine stand. I use 3-1/2"-long bolts, with hardened washers at both ends of the tubes.
