undercoating on a 1963 - NCRS Discussion Boards
  • Joe C.
    • April 30, 2001
    • 126
    I need to add undercoating on the front wheel wells. I see that Paragon has a green color primer, and that Ecklers has a rust semi black. Can any of these be used? Where do you get this undercoating? Auto supply? Car dealer? any help is appreciated.
  • G B.
    • December 1, 1974
    • 1407
    Re: undercoating on a 1963
    If you're talking about the thick black rubbery undercoating with the rough surface, I doubt you'll be able to find any rattle can that will give the right look.
    I have to use a can of commercial undercoating shot out of a "Shutz" spray gun at about 25 psi to get the right thickness and texture. A Shutz gun has a large (~3/8") spray tip. You can buy this set-up at an auto paint store.
    • Wayne W.
      • April 30, 1982
      • 3605
      Sounds like he is talking about primer.
