I've got a pile of old used Corvette transister ignition distributor parts from the sixties. I sure would appreciate some advice on how to test the stationary magnets (pole pieces) to determine if they are any good.
I've used an ohm meter to test the resistance across the two wiring terminals on five stationary pole pieces. These test readings varied from a low of .566 to a high of .848. Most were in the .566 to .603 range. Is this the best way to test them when off a vehicle? How can these readings be interpreted as a predictor of performance when installed?
Thanks for any help you can give me on this.
