Drum Brake Question - NCRS Discussion Boards
Drum Brake Question
  • john lokay
    Drum Brake Question
    What would cause a car with drum brakes (sorry guys this question pertains to a 61' Olds) to veer to the left when applying the brake with my hands off the steering wheel?
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Drum Brake Question
    L/brake worn out
    L/brake cylinder sticking
    R/cylinder leaking
    • Bill Purdy
      The problem could be adjustment as well
      • Kent K.
        • December 1, 1982
        • 1139
        John - Also, check tire pressures in all 4 tires.
        Kent #6201
        Kent
        NCM Founder - Member #718
        • Mike McKown
          Easy answer
          Your RIGHT front wheel cylinder is stuck. If that's not right, go to the other answers.
          • Mike McKown
            Re: Easy answer
            Or, your right front brake hose has collapsed.
