I have a set of Front/Rear sway bars from a later model (75-82) C3 that had the 'Gymkhana' FE7suspension. While the bushings for the 1 1/8" front bar are no problem, I am having a hard time locating the rear sway (11mm / 7/16") frame bushings.
GM doesn't list them anymore and other than poly bushings, the rubber factory type bushings are nowhere to be found.
Any suggestions?
Thanks!
Elm.
Any suggestions?
Thanks!
Elm.
