4657 Fuel Pump Rebuild. - NCRS Discussion Boards
  • Harry Sadlock
    When rebuilding the 4657 fuel pump is it mandatory to replace the two valves and the actuating lever?
    I'm rebuilding two, one is very dirty and clogged I know I must replace these parts, but the other one is very clean on the inside.
    Thank You
    Harry
    38513
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 4657 Fuel Pump Rebuild.
    No it's not necessary if the two valves are OK ( blow and suck) at the intake and out fitting to see if they are OK , but I would not change the actuating arm at all but the seal.
    • Harry Sadlock
      Roy, thanks for the post. That seal looks like it will be fun to get out! Any suggestions.
      Harry
      • Roy B.
        • February 1, 1975
        • 7044
        Well if you think the engine oil was not getting in to the pump for get it, but I pry it out with a screw driver then tap it back in.
