correct battery for 1978 - NCRS Discussion Boards
  • Ralph A.
    • May 31, 2002
    • 236
    Can someone tell me with the correct battery make and model for a 1978 corvette. Friend just purchased and we want him to get a real repo and not a off brand if he is going to change it anyway.
    RA
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
    Re: correct battery for 1978
    Ralph------
    While I'm not completely sure about this, I believe that the battery originally installed in 78 Corvettes was a sealed-type Delco Freedom battery. There were 2 differently rated batteries used depending upon whether the car was equipped with the HD battery option.
    As far as I know, the Delco Freedom battery is not currently reproduced. If I'm correct, it sort of makes moot the issue of obtaining a reproduction battery.
    • Barry #41479
      I have a 78 and have researched this and there is no reproduction battery being produced. I even called a couple of the more noted reproduction companies and was told that it would cost them about $50,000 to produce the prototype and they felt there was not enough of a restoration market currently to support the product. The battery was a sealed Delco Freedom with I believe 460 CCA, (dont have reference with me), so have your friend get a Delco sealed with "green light" and they will get the least amount of deductions when they have it judged.
      • Ken Liperi
        I'm going for an NCRS Top Flight this year and have looked for this Delco Freedom (green eye) battery with no luck. Delco says it's not around and a large repro company doesn't make it (past 1976 models). The NCRS Judging Gguide states that Model 87-5 (430 CCA) was the standard battery and model 89-5 (465 CCA) was the optional heavy-duty battery (RPO UA1 option). The top is blue plastic with 2 maintenance free square covers. The sides and bottom are white. "Delco Freedom Battery" is written at an angle across the right cover. A Delco "eye" is in the forward center of the right cover and should indicate "green" if battery is normal. I recall buying a new '77 Corvette and had problems because the factory mistakenly installed a standard battery instead of the heavy duty one, and the car had air and a rear defroster. So IF you find one, go heavy duty. And if anyone knows where any Delco battery is with one of these green "eyes" let me know!
