Where to find C3 deluxe door washers? - NCRS Discussion Boards
  • Christopher J. Bunsey
    I need the dimpled washers that go on the back-side of the deluxe door panel between the screw head and the door panel....I cant find them in the catalogs!
    Thanks!
    Chris
  • Lyle B.
    • May 23, 2012
    • 17
    Re: Where to find C3 deluxe door washers?
    As far as I know, there is no such place. I had found a hardware store that had the washers attached to the screw. I belive that this is the only way you will find them. I had bought mine at parkrose hardware in Portland, OR. Good luck. It took me quite awhile to find these.
