C3 77 Fuse Block Damage
  • Renee Narloch
    I removed a fuse and out came the clamps holding the fuse. Any suggestions on repair/replacement?
  • Ed Jennings
    Re: C3 77 Fuse Block Damage
    Check Lectric Limited. I know they have fuse blocks for the older cars as separate items.
    • Jack H.
      • April 1, 1990
      • 9893
      Buying the stand-alone fuse block and trying to install it properly isn't an easy job! LL's competition (M&H) puts a clear caution (no returns!) on this item because altogether too many novice electricians have ordered one thinking they'd save money over buying and installing an entire harness assy only to find you need special crimping equipment and some knowledge/skill to install the fuse block properly. Too many came back as 'returns' with evidence of obvious 'Bubbha' damage from botched installation attempts!
