1967 front shock washers - NCRS Discussion Boards
  • Louis F.
    • September 30, 1991
    • 132
    My front shock washers (metal and domed shaped) are losing there finish.I Would like to restore them.Any ideas what the best process is? Thanks, for any help.
    Re: 1967 front shock washers
    Louis-----
    To restore the original finish on these you'll need to strip off all of the existing finish. Then, you'll have to apply a phosphate finish followed by oiling. It's a lot of trouble, though, and this piece is still available new from GM for about 4 bucks, GM list, each. It's still available under the original part number, too, and is identical to the originals. GM #3790342 is what you want.
    • Louis F.
      • 132
      JOE, YOUR THE BEST !!!!! THANKS AGAIN, LOU
      • Peter L.
        • May 31, 1983
        • 1930
        Louis - As Joe mentioned, they are still available from the General, but unless your dealer stocks them you might have to buy a package of 10. Pete
          Pete-----
          This particular part is supplied 1 per package.
          Also, I forgot to mention earlier, when these retainers are used, one should also use bushing GM #3790341. These are also still available from GM and are packaged 1 to a package.
          You can use the standard shock bushings with the 3790342 retainers. However, the best installation is obtained using the 3790341 bushings which are designed for use with the 3790342 retainers.
