Are you tired of taking deducts for your service replacement windsplits, you know, the ones with smooth studs and pal nuts, instead of threaded studs like the originals? I discovered today, that you can carefully run a 6-32 die over the studs, and they will thread very nicely. You can only thread to within a little more than 1/8" from the backing plates, but once installed, you can't tell the difference! This may be old news to some of you, but I had never thought to try it, and it works good.
Regards, John McGraw
