Warning: Undefined array key 942 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
1967 N89 Bolt On Question -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I have read the archives and I have not seen the answer to this question.
Recently a 67 bolt on wheel appeared on Ebay. It had the thin ribs, deep outer lip, & grey paint with rough surface. On the reverse side, the wheel did not have the raised reinforcements. This wheel appears to be original but lacks the raised reinforcements. Could it be a very early KH wheel? Does anyone have any input? I have four of the originals and from what I can see this wheel looks like the real deal from the front.
Steve
email : sfarnish@aol.com
I'm no expert, but as I understand it, the original production N89 wheel should have the reinforcing ribs on the back side like the photo below, and will have standard 7/16" diameter chamfered lug stud holes (vs. the larger non-chamfered hole for the plain-shank cylindrical 7/8" hex lug nut used on the Corvette America reproductions).
