C-1 side window glass replacement - NCRS Discussion Boards
  • Dave T.
    Infrequent User
    • August 31, 2000
    • 21
    My driver's side window on my '60 cracked and I have the dated replacement. I plan to take the glass out of the door and take it to a glass shop to put the new piece in the frame. Are there any warnings or hints that I need to give to the glass shop before they have a go at it??
  • mike mccagh
    Re: C-1 side window glass replacement
    tell the shop to seat the glass in the channel with BLACK bedding, not the tan cork-like bedding most use. the black bedding is available from Lawson products--ya gotta buy a 50 or 100 foot roll though. good luck, mike
    • Roy B.
      • February 1, 1975
      • 7044
      Good time to polish the S/S frame first.
      • Larry P.
        • June 30, 1999
        • 481
        There is a rubber piece "rain drip molding" that goes on the bottom of the glass between the frame and glass that you will probably need. Make sure they
        install it with the notch to the front and outside.
        Larry
        • Dennis A.
          • April 30, 1999
          • 1010
          Dave...
          With a little effect, you can replace the window yourself, I can forward some instructions if you are interested.
          • Jim K.
            • September 30, 2003
            • 64
            Dennis, I would be interested in those instructions if you don't mind!
