ls6 exhaust - NCRS Discussion Boards
ls6 exhaust
  • Mike S.
    • March 1, 2005
    • 125
    ls6 exhaust
    Is ls6 exhaust different from ls5 as far as the sound.
    Re: ls6 exhaust
    Mike-----
    It's not different as far as any sound generated by the exhaust system, itself. The exhaust systems used for 1971 LS-5 and LS-6 were EXACTLY the same.
    • Mike S.
      • March 1, 2005
      • 125
      Re: thanks *NM*
      • Mark #28455
        the engine sounds different
        Most high performance engines have higher compression ratios and a camshaft with longer duration which opens the exhaust valve sooner - while the cylinder pressure is still higher. Unlike the LOUD exhausts commonly seen on pickup trucks that rumble like a garbage truck, the high perf motors have slightly more of a popping quality. Best example is to go to an NCRS meet and listen to an L88 and a 390 HP car. They definitely sound different with the exact same exhaust system.
        • Bill Stephenson
          Re: the engine sounds different
          --------An LS6 sounds so much better than an LS5 that it sounds like different exhaust..........Bill S
            Bill------
            As I've mentioned before, to my ear the 1971 LS-6 was the best sounding Corvette engine EVER (WITH original mufflers, of course). And, the 1971 LS-6 was a 9.0:1 compression engine. So much for this notion that it takes high compression to "make an engine sound good".
            • Dick W.
              • 10483
              Just put LS-6 pistons in an LS-5 and add GM offroad mufflers (discontinued from production), the you have a real good sounding car. If you every see a "frog green" 72 with the tag 72LS-5 you will know what I am talking about.
              Dick Whittington
              • Bill Stephenson
                Joe,
                --------Many years ago when BG was still at the old Bloominton fairgrounds I drove my LS6 down to be judged. On the way down in a caravan of sorts I decided that the lead car was going a tad slow (I was back about four cars). I will never forget the sound of an LS6 at 6200RPM in fourth gear (3:55 gears). That car never got near a trailer while I owned it as it was just too much fun to drive...........Bill S
