What coil is a "292" coil? - NCRS Discussion Boards
  • Timothy B.
    • January 1, 2004
    • 438
    I thought I would check out my Delco coil, since it is older and I wanted to have a backup for it in case I had an on-road failure. It's resistance measured about 11.1K ohms from spark lead to either terminal, and about 1.9 ohm. These numbers seem outside of normal. This may not be the right coil for my 67 320/300hp car with standard points ignition. Car runs OK. Anyone know what it is?
