I have two different u-joint flanges on my half shafts. One is 5/16" thick where the bolts pass through to connect to the spindle flange and the other is 7/16" thick. The thinner of the two apears to be original and has part of a part number on it but I can only identify 3 numbers. I would like to identify the correct flange so I can get a set that matches. On another subject I need help on the finish for the lock nuts holding the steering knuckle to the front spindal. I got a set of bolts and nuts from Dr R that are not correct for a 63 the bolts are both the same length. The lock nuts are cad plated, is this correct? The ones I removed are black phosphate on the underside of the nuts the rest was just rust. Thanks in advance for aney information. I just got my break cylinders and master cylinders back from White Post Restorations they did a great job I shiped them last friday and got them back this friday. So I thank the person that recomended them.
Carl
Carl
