57 carb filter - NCRS Discussion Boards
57 carb filter
  • paul Bowers
    57 carb filter
    can the carb. filter on single four be domed or flat, some catalogs offer both for the same yr. so would either be considered correct also what type of tubing goes from filter to carb. thanks allot
    Paul
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 57 carb filter
    Domed and a short brass threaded tube about 1inc.long, Domed and flat had the same part # so some people think ether was used
      Re: 57 carb filter
      A brass nipple threaded into the carb fuel inlet, and the fuel filter threaded onto the other end of the nipple. Another adapter threaded into the inlet side of the filter, and accepted the SAE flare fitting on the steel line from the fuel pump.
      • paul Bowers
        Re: 57 carb filter
        thanks John and Joe
        Paul
