67' dash-out - NCRS Discussion Boards
67' dash-out
  • Steve Shanks
    67' dash-out
    I'm very close to pulling out the dash for new paint, lenses and bulbs. Sending the clock to Clockworks and need a new speedo cable. The g/box liner does show the usual wear on the back, sides, and bottom- need to know who sells the best and correct liner for judging? Also is there any small details I could do or replace while the dash is out rather than later?
    Just waiting for spring like evryone! Thanks Steve S
  • Gordon Peterson #4961
    How's the radio? speaker? *NM*
      Re: 67' dash-out
      Steve -
      "While you're in there", this is a great time to remove the brake/clutch pedal support assembly, clean it up, and replace the plastic bushings for the brake pedal and clutch pivot shaft; lube the new ones well so you don't have slop, groans, and squeaks later.
      • Steve Shanks
        Re: 67' dash-out
        Thanks Gordon ..I was concerned about the radio or speaker:one or both has some static and I will check them out. But I hadn't thought of the brake/clutch assembly or bushings...will do! Thanks for your responses.
