57 gas tank - NCRS Discussion Boards
57 gas tank
  • paul Bowers
    57 gas tank
    I would like to drain the rest of the bad gas from my tank, is there an (easy acessible plug) on that yr. or do I have to remove other parts also would i just put the plug back in or does it require some sort og gasket thanks
    Paul
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: 57 gas tank
    Paul, Believe you'll find a 1/8" pipe drain plug on the bottom right hand side. Now, all you have to do is loosen it !!! Good luck, Dennis
