"M" date code on block
  • Brandon Korman (28984)
    • April 1, 1997
    • 15
    Have you guys ever heard of an "M" date code on a block? Someone told me he had an "M" dated 386 block, and I thought he made a mistake,because they only went to "L" (December). I've since seen a few advertised. Anyone know anything about this? Could an M-12-8 be made in January '69?
    thanks in advance, Brandon
  • Dennis Clark (7068)
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: "M" date code on block
    I have not seen an M block or cylinder head.
    • Mark Gorney (35760)
      • March 1, 2001
      • 227
      Brandon –
      If it is a small block and cast in Saginaw, yes. In volume twenty-seven, number four, spring 2001, page 41 of The Corvette Restorer is an article by Gene Gamache addressing this casting anomaly. The “M” designation identified the castings (cylinder& case) as specials. The date tag was used for tracking the parts through processing. If the castings were approved by the customer (Flint), they were released into production and a few cases made it into Corvettes. Dan Pepper a member in Seattle has an "M" block in his '69 coupe.
      Mark #35760
        • January 1, 1984
        • 2409
        Mark, Now that you mention it...
        ... I did see one at a Chapter Judging event several years back. I ended up calling Terry McManmon while the car was being judged. Good thing he answered the phone and got us straightened out on the possibility of the "M"...
        • Dan Pepper
          As Mark mentioned, my '69 350/350 October build coupe has an "M" dated casing; "M48" to be exact. According to the article Mark mentions, these "special" blocks were cast in batches of 50 or so. A few from each "experimental" batch were cut-up for inspection. If the castings past muster, those remaining were released to the line. Let me know if you'd like any more info regarding my particular car.
