61 Harmonic Balancer Color and assembly - NCRS Discussion Boards
  • William Gallentine
    I have looked in the 1st issue of the Nolands restoration guide and an assembly manual with no luck. I need to know what is the finish on the HB? I purchased a new HB from Corvette America for a 270 HP and it showed a spacer, does the spacer go between the pully and HB or does it go on the crank before the HB?
    Thanks for your help again. I am getting close pics to soon follow. Bill
  • Ted S.
    • January 1, 1998
    • 747
    Re: 61 Harmonic Balancer Color and assembly
    Bill, the spacer goes on the crank snout before the harmonic balancer goes on. It spaces the balancer out to compensate for the thickness of the motor mount. Hope this helps.
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      Bill, The "HB" is painted along with the rest of the engine asy.
      • Loren L.
        • April 30, 1976
        • 4104
        Is the HB 6 1/2" in diameter, with holes
        in the outer ring?
