57 spark plug clips - NCRS Discussion Boards
57 spark plug clips
  • paul Bowers
    57 spark plug clips
    I know someone knows this cause I saw it once before,butI forget to copy it
    there are spark plug clips on both sides in frt.oil pan, what pan bolt starting from frt. does these two clips bolt to second there are also block spark plug clips on both sides of blk. where do these bolt to blk, are there predrilled holes somewhere on blk. if so where are they located these or small things but if I'm there I might as well try to replace items like these
    as always thanks alot
    Paul
    Re: 57 spark plug clips
    Paul -
    The oil pan rail clips go under the pan bolts adjacent to the lowest point of the "boomerang" shields that contain the plug wires; the bolted-on plug wire guides behind the heads attach to pre-drilled/tapped 1/4"-20 holes in the rear block flange on both sides. Details are in the '57 Assembly Manual in Section 12, Sheet 10.
