C1 gas guage changes when braking - NCRS Discussion Boards
  • Gary H.
    • July 31, 1982
    • 10
    My C1 gas guage registers 1/4 tank until I hit the brakes and then it reads 3/4 tank full. After releasing brakes it goes back to registering 1/4 tank. Any ideas on where to start trouble shooting?
    Gary
  • John M.
    • January 1, 1999
    • 1553
    Re: C1 gas guage changes when braking
    This is a classic grounding problem. Run a dedicated grounding wire from the tank sender to the frame, and the problem should go away.
    Regards, John McGraw
    • Ed Jennings
      To be just a bit more specific, run the ground wire from the sending unit FLANGE to the frame. You can snake a wire down the same hole the fuel lines go through and attach to a "stealth" location on the frame. Use one of those serrated washers on the attaching screw to get a better connection.
      • Mike E.
        • February 28, 1975
        • 5134
        Gary,
        The great thing is--if you start running low on gas, just put on the brake lightly, and you'll be fine!
        • Donald B.
          • May 31, 2004
          • 299
          In the same vane - jack up the rear end and you will get great gas mileage because you will always be going down hill.
