Just me again-
I'm replacing the transmission on my 69' Coupe from the original M-21 to an
M-20 from a 72' Vette. Along with swapping the driveshaft, both yokes and related U-Joints etc, I also need to replace the clutch (from 10 to 26 spline).
I have read several threads out here regarding Pilot Bushings vs Bearings and have found the majority of the comments are in favor of the bushing.
With that said, I want to install a pilot bearing instead (I can never be mainstream ;-).
My question is:
Is there a particular way to install this bearing?
The beaing is closed on one end and the 'cage' is open on the other. I can't find any documentation anywhere that specifies which end should face the engine vs the transmission.
From my perspective, I would think you would want to install the bearing with the open 'cage' side facing the engine- That way, you can pack the cavity in the crank full of grease and hopefully avoid the 'dry bearing' failures I've read so much about. If I install it the other way, you are pretty much stuck with only having the grease that can be physically contained within the bearing itself (which isn't much).
Any thoughts, suggestions, stories or advice (other than don't use the bearing)?
Thanks!
Elm.
My question is:
Thanks!
Elm.
