the secondaries on the 69 tri-power end carbs have a vac line coming from the primary carb, i am under the impression these lines should have a white stripe? and the vacuum advance line also should have a white stripe? are clips used at the nipples on these lines?
tri-power vacuum lines
clips as in clamps? NONE
Yours truly was the first source of this item in the Corvette aftermarket. It even generated a debate about the width of the White stripe. Although not referenced in the AIM. I did find a reference to it in one official GM publication. I'm guessing, but it was about 15 years ago when I first saw it on a 5K mile 1963. Then on a friends 1962. It even found it on a 1970 I bought part of lasr week. Now its so common, probably Home Depot carries it.
Whitey F*rd- Top
