Hey Doc, C2 L/H outer Headlight Pivot question - NCRS Discussion Boards
  • Scott Marzahl
    One my existing L/H outer pivot there is the remains of a plastic piece that is attached to the "cam" end. Does anyone know if that piece is available, I can't locate it in any catalog.
    Scott
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: Hey Doc, C2 L/H outer Headlight Pivot question
    You didn't mention the year.... however on a '67 there are no plastic pieces on the headlite bucket shafts. None show in the assembly manual either. Could you be talking about the seals which are a metal and rubber stepped/grooved "washer" type device that is black and is the first item installed onto the shaft when assembling the entire assy???
    • Scott Marzahl
      Steve, yes it is a '67. No, there is some white plastic shaped to the cam end, I assume it is some type of rub strip to prevent the metal cam from wearing.
      • Stephen L.
        • May 31, 1984
        • 3148
        I can't visualize the "cam" you are talking about. Are you inside the headlite bucket or on the rotating 3/4 inch diameter shaft external of the bucket??
        • Scott Marzahl
          Steve, I'm outside the bucket. I can send you a photo if you send me an email at:
          Scott.m.marzahl@boeing.com
