i have a 1966 425 coupe. when i try to start it, it fires right up. then on its' own almost dies, then returns to idle, but not before backfiring through the secondaries and of course a little flame appears. we've noticed that every time this happens, you can see a little sparking coming from the back of the alternator by one of the diodes. my question is can i try putting a non-t.i. alternator on the car to see if this is the cause of my starting problems before i commit to rebuilding my t.i. alternator, which by the way is brand new ? the timing and the valves are set correctly. i figure that the sparking of the alternator doide is causing some sort of electrical surge and causing the backfire. am i close with my diagnosis ? will the installation of a non-t.i. alternator just to see if it solves the problem ruin anything ?
thanks,
kevin
thanks,
kevin
