65-327 block - NCRS Discussion Boards
65-327 block
  • Dean
    65-327 block
    I just looked at a supposedly 65-327 block, casting number 3956618, the pad # is as follows, TO408HN, is this a vette block? Thanks in advance, Dean #33398
  • William C.
    • May 31, 1975
    • 6037
    Re: 65-327 block
    Two keys here, the "T" in the assembly stamp indicates an engine assembled in Tonawanda, New York. All Smallblock Corvette engines were assembled in Flint (Mich) and started with an F--- in '65. Secondly the only documented casting numbers I am aware of are the '870 (most common) and the '180 (somewhat uncommon)
    Bill Clupper #618
      Re: 65-327 block
      Dean -
      The 3956618 casting was used as follows:
      '69 Camaro 302 cu. in. Z-28 4-bolt mains '69 Corvette 350 cu. in. 300hp & 350hp 4-bolt mains '69-'74 350 cu. in. All pass. cars (exc. Corvette) 2-bolt mains '69-'76 350 cu. in. Truck 2-bolt mains
      Don't know what the stamped suffix means (someone else here will), but the "TO" prefix is Tonawanda Engine; all Corvette small-blocks were made at Flint Engine.
      John
      • Dan 80
        Re: 65-327 block
        One more piece of information that would have been helpful is the casting date. As I believe this was a short run block used only in 1969 models from December '68 through April '69 in 2 and 4 bolt mains. It replaced the "386" block (Jan-Dec '68)also a short run block. All used for 302, 327, and 350 cu. in. engines which have a common 4" bore.
        The stamped number T0408HN indicated a Tonawanda built, on April 8th, 300hp 350cu. in. with Turbohydramatic trans for full size passenger car.
