Frame alignment - NCRS Discussion Boards
Frame alignment
  • Carl S.
    • July 31, 2002
    • 75
    Frame alignment
    What is the vertical error allowed for the front end of frame reletive to the rear. Trying to determin what amount of twist in a frame is to much. I am using the difference between all given points and find some futher out than I expected, most are within 3/16 from the stated but I found two in the front end that are 3/8 out on one side of the frame starting with #1 body mount going forward. I am having someone else double check my findings.Thanks to all that respond.
    Carl
  • Bill W.
    • March 1, 1980
    • 2000
    Re: Frame alignment
    1/4 "max... The closer it is the less headaches you will have in the future.Bill
