C1 wireing all works except---- - NCRS Discussion Boards
  • Larry P.
    • June 30, 1999
    • 481
    All new wireing on my 60 and everything works except the left turn signal. The front, rear and dash all light but won't blink. The right works fine. All new bulbs. What else is there?
    Larry
  • Ed Jennings
    Re: C1 wireing all works except----
    You say everything else works. Does the left braake light work? If so, it sounds like a defective t/s switch.
    • Larry P.
      • June 30, 1999
      • 481
      The brakes and lights work. The lights all go on on the left, just won't blink.
      I'll check the switch, but it's brand new.
      • Ed Jennings
        If the light comes on but won't blink, it's not the switch. Is the front t/s lamp coming on also? Usually when a signal won't blink it's due to one of the two lamps in the circuit being out. When this happens there isn't enough amperage to make the flasher work. If both front and rear lamps are on but don't blink, the flasher may not have quite the right resistave value. You might try another flasher just to check.
        • Larry P.
          • June 30, 1999
          • 481
          It's also new and all from Lectric Limited. I would assume they would get it right. I'll try another flasher.
          • Larry P.
            • June 30, 1999
            • 481
            A new flasher fixed the blinker. BUT, before I installed it, When I opened the door I noticed the courtesy light didn't go on. The dash lights and coutesy lights were working and quit. I installed tach and speedo cables but can't find anything wrong and the fuses are all good.
            One step foreward and two back!
            still frustrated,
            Larry
            • Ed Jennings
              Check connections at headlight switch *NM*
              • Larry P.
                • June 30, 1999
                • 481
                Re: Check connections at headlight switch
                Connections at ignition are on. All wireing and switches are new. All was working. The brake lights don't work either.
                • Ed Jennings
                  Check the connections at the headlight switch. As for the brake lights, they feed off the fuse panel. See if you have voltage al the time on one side of the brake light switch. If not follow back to the fuse panel.
