Part # help=Joe ??? - NCRS Discussion Boards
Part # help=Joe ???
  • Tom S.
    • March 1, 2004
    • 1087
    Part # help=Joe ???
    I found 2 sheet metal tags, 1 under each front seat. The # 3958735 is on the top. Then below that is SI -M THEN TO THE RIGHT OF THAT IS 5-69.Is that the seat part # Saint Louis mo. for the plant and a build date of may 69?That is what I take it to be, but looked in the judging manual and nada. it looks like an S i not Sl?
    Thanks in advance.Tom
    Re: Part # help=Joe ???
    Typical factory production included PN ID tags for the seat frame assy installed on the lower frame seat springs. Due to poor underseat visibility, this aspect of factory originality isn't judged which explains why you don't find a reference to the tags in your JG book....
    You should be able to match the PN embossed on the tag with the seat frame PN called out in your copy of the AIM book.
