C2 Posi? - NCRS Discussion Boards
C2 Posi?
  • Mike Swanson
    C2 Posi?
    This may be a bit premature since I haven't looked at the numbers yet but I was looking at my 67 L79 diff and noticed a red posi tag. I was confused since I can rotate the right wheel when I jack up one side. Did someone just put a posi tag on the fill plug or is there maybe something wrong within.
    Mike
    #39237
  • Mike McKown
    Re: C2 Posi?
    Sounds like the clutches are gone.
      Re: C2 Posi?
      Posi was an option - what are the number stampings on the bottom of the diff carrier (between the spring mount plate and the camber strut bracket)?
      • Mike Swanson
        Re: C2 Posi?
        John,
        Thanks for the reply. I am going to check today and will post the numbers.
        Mike
