I'm ready to re-install the fuel tank and looking for suggestions/tips on the process.
1. Should the Bands be installed before lowering the tank into place? If so, any suggestions on how to keep the straps out of the way?
2. Should the filler hose be attached to the tank before lowering the tank into place and then "feel around" and get the filler neck to slide into the filler hose and then tighten both hose clamps?
Any suggestions will be appreciated, as usual.
