T-10 trans #'s
  • Joseph Rock (16026)
    • 94
    T-10 trans #'s
    I know my transmission is a "mutt" from the following info found on the exterior: tailhousing - "M or H", "4 22 58", "T10-7A", "WG DIV". side access cover - "12-4-61".
    main body - "T10-1B", "WG DIV", "02", "L 14 62".
    In the course of trying to sell the tranmission, I was asked to verify these markings: 3743368 main case, 3707195 tail shaft, 3741357 side cover.
    If these are on the trans, I don't see them. Where should I look ? Thanks.
  • John Hinckley (29964)
    Re: T-10 trans #'s
    Joe -
    Doubt if you'll find them - dunno where the tailhousing and side cover numbers came from, but the main case number (3743368) is for a '58-'63 Saginaw cast-iron 3-speed transmission, and that transmission never used either of the other numbers for tailhousing and side cover (at least in Corvette usage).
    • William Clupper (618)
      • June 1, 1975
      • 6037
      Re: T-10 trans #'s *NM*
      Bill Clupper #618
