The Hoses I got from CC are not gonna fit the fittings on my manifold or water pump. I got two different size hoses. I assume the smaller is the out, back to the manifold and the larger goes from the pump to the heater core. The fittings on my manifold are about 7/8 outside diameter. The smaller hose is 5/8 ID.
What size should the fittings be on the mainfold and water pump? Is this another case of incorrect "correct" hoses?
LP
LP
