C1 HOOD CABLE - NCRS Discussion Boards
C1 HOOD CABLE
  • Michael D.
    • August 31, 2001
    • 63
    C1 HOOD CABLE
    where does the cable for the passingers side hood release run? inside the passinger compartment or across the back of the engine. i have a 58, & 59 and neither have a hole that fits the cable gromet ( oblong)
  • Larry P.
    • June 30, 1999
    • 481
    Re: C1 HOOD CABLE
    Inside, the holes are both right above each female latch.
    • Pat #25912
      Re: C1 HOOD CABLE
      Michael, on my '59 (Jan 30) car the oblong grommet for the pass side cable is
      right behind the accel lever (looking from inside the engine compartment) about 2" above the pivot. My '59 uses the '58 style female latches. Later cars use the same type latch shown in the '59 AIM and I believe they exit the firewall closer to the female latch. Pat G.
      • Michael D.
        • August 31, 2001
        • 63
        Re: C1 HOOD CABLE
        IS THERE A HOLE IN THE FIREWALL INSULATION? ABOVE THE ACELLERATOR PIVIOT? THE LATER STYLE COME IN ABOVE THE FEMALE LATCH BUT THE 58 E59 HAVE TO COME FROM BELOW TO FUNCTION. THANKS
        • Pat #25912
          pic of grommet
          Michael, in the pic you can see the grommet by the accel lever. The clip on the tunnel in the lower left is for the cable as well. I believe this to be correct but I ain't no expert an am open to correction. Pat G.
          • Pat #25912
            pic of firewall insulation
            I hear ya Mike, you can turn the caps off. Here is a pic from under the dash. The insullation is repro that I bought within the last 4 months. I assume the hole on the right is for the cable but I haven't run the cable yet. The '58 AIM shows the routing for early '59 cars, if you need a copy I'd be happy to fax it to you. The '59 AIM shows later '59 cars. Pat G.
            • Larry P.
              • June 30, 1999
              • 481
              Whoops
              Shouldn't have assumed 58 and 59 were same as 60.
