Anyone have the torque specs for tie rod end nuts and idler arm nut? Can't find it either the assembly or chassis service manual...
STEERING COMPONENTS TORQUE SPECS
Re: STEERING COMPONENTS TORQUE SPECS
Rob----
The idler arm-to-relay rod nut is torqued to 50 lb/ft + additional torque necessary to align the castle nut with the hole for the cotter pin (not to exceed 60 lb/ft).
The tie rod end stud nuts are torqued to 35 lb/ft + the additional torque necessary to align the castle nut with the hole for the cotter pin (not to exceed 50 lb/ft).In Appreciation of John Hinckley- Top
