I have drove my car alot in the last few days, an I am having trouble with the t-top on the pas side staying tight. I let out the screws on the latch an that helped but now it is leaking air again. the seals are new, I dont know why it wont stay tight, anyone know are have had this with t-tops?
T-Tops
Re: T-Tops
Lyndon:
The tops have as many as 8 adjustment points. In the past when I have replaced the tops with NOS GM weatherstripping, I would play with all the posistions to align the tops straighter and more uniform in appearance than the factory did. This often took a lot of time in adjusting all the different positions for the top to seal around the winshield and divider reinforcement structure between the tops as well as fore and aft positioning.
Be patient, there is also a Corvette News issue in 1971 that shows and demonstrates all the different locations for positioning the tops.- Top
Re: T-Tops
I think I found the problem, the guide pin was lose on that side, I hope that works it was real lose, I will check later when I drive again. you would no when I get my car out again gas would go to over 2.00$ dollors a galon, an that 454 will not pass an gas station.- Top
Re: T-Tops
Hi Warren I'd Like to see that article from the Corvette News 1971 (what month) I'm missing these ones (Dec/Jan 71, Feb/Mar71, Apr/May71, Jun/Jul71,) if there is anyway to see the info it would be appreciated because my left top needs an adjustment.
Thanks.
Ken.- Top
