62 adding 4 way flasher - NCRS Discussion Boards
  • Gene M.
    • April 1, 1985
    • 4232
    Does anybody know where to get a switch to add 4 way flasher to a 62? I was planning on mounting it unobtrusivly under the dash. Cutting into the original harness is not a problem as previous owners already made a mess of it. I'm all set with a flasher setup, just need the switch.
  • Dick W.
    • 10483
    Re: 62 adding 4 way flasher
    Gene, Grote, Signal Stat, and others used to make a kit to install four way flashers. I cannot find one listed in either's online catalog. Next best bet is to go to a truck salvage yard. They were factory installed on Dodges and Internationals of the 60's era. Probably several more used them.
    I have one if I could find it I will be glad to give it to you. Bad thing is that all things like that are stored in a 48 storage van right now until I get another shop.
    Dick Whittington
