air leaks - NCRS Discussion Boards
air leaks
  • lyndon sharpton
    air leaks
    I think I have solved the t-top leak, now it seams that air is coming in the pas side door glass. I see a good gap in the A post an the door glass. OK how can I adjust the door glass to come in more?
  • Dick W.
    • 10483
    Re: air leaks
    Get your factory service manual out. It details how to make this adjustment. Basically you remove the door panel. There are adjustments to move the glass in or out, front up or down and the same for the rear. Just takes patience and time. The adjustments that you need to make are at the bottom of the window tracks.
    Dick Whittington
    • lyndon sharpton
      Re: air leaks
      thanks dick
      • Stephen W.
        • March 1, 2002
        • 301
        Re: air leaks
        I like to use a piece of paper to check the glass against the weatherstrip so I can pull it out with a reasonable drag. I adjust the glass for uniform drag on all areas.
